Fuel pipe / pump
For those who don't speak dutch
Saffles
Fuel pipe / pump
Bericht door Saffles »
Hi,
I need to disconnect the fuel pipes from the fuel tank so that i can remove the pump and empty the tank (the fuel has gone bad - very old).
How can i remove the fuel pipe connector?
Thanks
www.safrane.info
Email: Saffles@
2.5 20V Ph2
Re: Fuel pipe / pump
Perhaps this helps:
https://www.honestjohn.co.uk/forum/post ... tm?t=76596
Or check Youtube?
Saffles
Yeah I tried that.. lol. Couldn't find anything..
Anyway I managed to get them off - I cut up a plastic bottle and used that inside the connector!
When putting the pump back in, it seemed a bit too tall due to the spring and vertical part that goes up and down. Only thing I could do was push down on it. Was that correct?
www.safrane.info
Email: Saffles@
2.5 20V Ph2
Yes, thats normal, you have to push it down.
